How to convert 'Localization Table: Default' to other languages when changed language from runtimeDD
MM_10159448
I have 100 token created in Localization Table: Default', Now I want to convert and see in runtime whenever changed languages from dropdown in runtime.
Please suggest my any service or code which should convert to other languages automatically
@MM_10159448 ,
You'll need to add the translation values in each of those languages.  It does not do the translation for you.  I would suggest using a service like Google Translate.  Then open each language localization table you'd like to support and enter those values
- Nick
@MM_10159448 ,
I would suggest creating a service that changes the language preferences of your user to whichever language you choose in the dropdown.  You may need to refresh the page. You can use this service:
Users["myUser"].SetLanguagePreferences({
	preferences: newLanguage /* STRING */
Hope that helps
- Nick
Hi Nick,
Thank you for your reply,
This Service, I am already using but the problem is.
I have added some new token in default as below
I have selected language in runtime from Dropdown list, refreshed browser and verified but its not converted in other languages.
Please let me know what is the issue?
@MM_10159448 ,
- Nick
create another localization for required language and put all translated values in custom localization which is newly created . so that it available as table in system which can be used in mashup
