I am facing the same issue. I am able to move, copy and delete the files when EMS is running in my local computer. But when EMS is running in remote desktop I am only able to copy the files. May be its due to the restricted permission in remote system.
Yes, that indeed turned out to be permission issue in the remote desktop. I had to change the settings under the security tab in properties of the folder and then it started to work as expected.
That does sound like a permissions issue
