How to copy the values of one infotable with row count of 33 into an infotable with row count 35
SOLVED
Newbie
Hi all,
               I have an infotable1 (list) in which there is a field called hours(rowcount is 33)
I have another infotable2 (Monthavg) of the same datashape as linfotable1 but the rowcount is 35
var rem = me.Monthavg();
for(j=0;j<count;j++)  //Here count is row count of Infotable 2 (that is 35)
    var rec ={ };
   if(rem.rows!= undefined)
    rec.days = rem.rows.days ;
    if(rem.rows== undefined)
    rec.days = 0;
infotable2.AddRow(rec);
For this code snippet I'm getting this error
where 33 is the row count of  infotable 2 (rem in the above code)
How do I copy values? What is the alternative here?
1 ACCEPTED SOLUTION
Re: How to copy the values of one infotable with row count of 33 into an infotable with row count 35
Try myinfotablename2.rows[35].fieldname = myInfotablename1.rows[33].hours
1 REPLY 1
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
