I need to create a progress bar widget has shown below, is there any way of creating the progress bar widget??
You can create a custom widget with some js, html/css.
This would be helpfull
http://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/Supporting%20files/WidgetAPI-IDE.pdf
If you have some problems specify your problem.
Usually it's done with Shape widget which has a fill percentage.
