The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
You could build it into the service that accepts the data and use it to trigger an alert of choice or just directly do what you require in your service (or linked service)
How are you actually looking to use this?
Usually a user would be in an experience and doing different actions that cause a response that Thingworx process, and then Vuforia receives/retrieves from Thingworx.
Not sure if that is your use case, that should be covered in some of the standard Vuforia use cases.
I have a query result and if that result exceeds and expected range it should send an alert.
Is this query triggered in Thingworx based on an timer or data change or is this query triggered within the Vuforia experience?
It is a live data that keeps changing and this data is coming from OSIPI to TWX. It is coming as a service . How to create an alert on the service.
