Hi, Thingworx Widget default look like this
and i has two question
1. how legend place inside widget?
2. can i make widget design like a picture?
You can create your own widgets see some example posts below for the how
I have created also created see attached percentpie
Also a very basic Just Gauge usage see attached just-gauge - The ide layout is not welll defined but shows how to use justGage.com
Previous Posts
Title |
Widget Extensions Using AAGRID a JS library in Developer Community |
Previous Posts
Title |
if so, is possible make widget style like a picture?
Also, it is difficult to know how to attach data and how to design it. Sorry.
Just Gauge provides similar gauges to the ones posted above. Try to use the extension blog mentioned about to understand how create extensions and take the JustGage primer attached and extend as needed.
If you need help post questions
