The current lint rule require each line end with semi ';' , can I change the rule ?
Sean
Hi @seanccc ,
If you feel that the OOTB editor isn't doing the job, there's a way to change it.
https://github.com/ptc-iot-sharing/MonacoEditorTWX
It's an editor based on Monaco(the open source library for Visual Studio Code), and you'll find that it offers a far superior experience.
Follow the instructions of how to install there and you should be good to go. It changes the editor for services and the CustomCSS tab in the mashup builder.
BR,
Gabriel
Hi @seanccc.
I don't think ThingWorx allows changing the rules.
If interested, you can submit this as a request on the ThingWorx Ideas page. This will allow others to vote for it in order to increase it's chances of being considered for a future release.
--Sharon
Hi @seanccc.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Hi @seanccc ,
BR,
Gabriel
