On click of button file got save to repository. How can i download the file from repository. Is there any widget i can use please suggest.
Hi @SandeepRatnani,
On the repository thing itself, you have a service called "GetFileListingWithLinks". In the output of the service is a field called "downloadLink" that works as a download button.
It can be exposed in the front end inside a grid.
Hope this helps,
Kind regards,
Johan Bester
Hi @SandeepRatnani,
Hope this helps,
Kind regards,
Johan Bester
Hi @SandeepRatnani.
If the solution posted by @jbester helped to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
