How to download latest thingworx extension sdk? Ex. Thingworx 8.5.4 SDK for JAVA.
You can find extension here: https://marketplace.ptc.com/apps/193524/java-sdk#!overview
Or from support portal (see attached image).
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Thanks for the reply. How can we identify Thingworx 8.5 equivalent java SDK or other versions?
Sathishkumar C.
Usually, the latest version found on Support Portal is compatible with Thingworx 8.5.
Hope it helps,
Raluca Edu
No. Thingwox software download page itself having Java Extension SDK.
Hi @Sathishkumar_C.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
