How to dynamic load thing?
jaiminLee
6-Contributor
Hello. every body.
I have a question.
I am doing mashup design.
First. Entry Picker widget.
Second. Button widget
Third. DynamicThings thing.
Fourth. Grid widget
Fifth. QueryPropertyHistory Action.
and then I want show Data from selected entry picker.
But I can't see result.
I want to see the results from dynamically things.
Could you help me.
9 REPLIES 9
Get service results from Dynamic Thing, you should use ThingTemplate as data source, and Enable Dynamic selection.
jaiminLee
6-Contributor
(To:zyuan1)
Thank you.
But My problem is not solved.
I can mashup design (Thing+ grid+ querypropertyhistory).
But I can't make [Ting list (dynamic select from entry picker) + girid + querypropertyhistory)]
Then you need to customize a service, Thingname is the service input that receives the entity name.
// result: INFOTABLE dataShape: ""
var result = Things["Thingname"].QueryPropertyHistory({
oldestFirst: undefined /* BOOLEAN */,
maxItems: undefined /* NUMBER */,
endDate: undefined /* DATETIME */,
query: undefined /* QUERY */,
startDate: undefined /* DATETIME */
jaiminLee
6-Contributor
(To:zyuan1)
Where and how do I create a service?
Create a service in any Thing that works for you, and then add this service through mashup data source. It's the most basic tasks in Thingworx.
jaiminLee
6-Contributor
(To:zyuan1)
Thank you very much.
I certainly understood.
But  I can't run it .  how can i set query parameter.
The query is a filter, if you don't need to manipulate the property history, you can leave it blank, just have a string input and a infotable output.
jaiminLee
6-Contributor
(To:zyuan1)
Ok I see.
Last Question.
How to link out property.
Now I set out property is  datatype INFOTABLE.
I don't know out put datatype.
leave the datashape blank, and bind the service output to the Grid.
