Is it possible to update the Title of a Master Mashup dynamically?
Thanks in advance
I think this is not available in ThingWorx for now.
I suggest you can also request it at https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas.
The more votes your request post got, the higher possibility it gets implemented in the future versions.
Hope it helps.
I don't believe the solution referenced above (using JQuery) will work anymore due to R&D's security concerns with JQuery. See one of the responses on this article for the specific response:
https://community.ptc.com/t5/ThingWorx-Developers/JQuery-in-mashup-function-ThingWorx-9-1/m-p/715943
Thanks For the Response. Is the any other way to get title Dynamically.
Hope it helps.
