Hi All,
I have created a Project and in that I am creating another entities (Thing ,DataShape etc.) which is required for our project
So If I export that Project will all entities that are associated with that Project will be exported ?
and also If after Export done and import the exported project in another server those entities will work fine?
Lav
You can select export all entities, by project name, that will export all the entities in the project. Can import the same to any other server as well. If you don't want to see the individual xml files, go for .twx format, it would be easier.
I would always advise for the xml format, just because it's easier to change something in the case you really want to.
twx format was created some time ago just to have freedom from the xml format (in case we decided not to export as xml, which we did not do yet).
