How to filter stream entries with no data tags
sabharees
I have multiple stream entries for few entries, we use data tags and for other entries we are not using data tags.
Now, I have to get only stream entries without tags ..
Is there is any way to achieve this ??
I tried filter snippets but it is not working as expected for no data tag entries.
2 REPLIES 2
slangley
23-Emerald II
(To:sabharees)
 @sabharees.
We're not clear on your use case.  Can you please provide more information?
--Sharon
BABA-SHYAM
(To:sabharees)
You can try by filtering data with tag using below query.
var query = {
"filters":{
"type": "EQ",
"fieldName": "tag",
"value": ""
if above query doesn't give you desired result try using below.
var query = {
"filters":{
"type": "NE",
"fieldName": "tags",
"value": "DataTag1;DataTag2;DataTag3"
Regards
Shyam
