I want to freeze a column in ptc-grid widget. I am using 9.3.1 version
Hi @AA_13644892 , Not part of ThingWorx Platform functionality
You may refer to the below attached link for the same:
Hi @AA_13644892 ,
It appears that there is an answer to your question. It would be great if you could designate it as the Accepted Solution for the benefit of other community members who may have the same question.
If this response did not answer your question, please post your current status so that we can continue to help.
Thanks for using the PTC Community!
Charles
