How to get ThingWorx Remote Thing Property Change History details for past 3 years
Sid_Del
How can I get Thingworx Remote Thing Property Change History details :
From Thingworx Composer---> Remote Thing ---> Change History Tab/Page I am able to view last few days entry only but I need to check past 3 years data what all new properties were added and which user added those properties. Attaching you screenshot of Change History Tab which I am refering.
Any help would be grateful.
Sid
PaiChung
22-Sapphire I
(To:Sid_Del)
By default the log settings have a roll over and retain 7 days and then purge, this is so that the system won't run out of space.
If you want to retain those logs longer, I recommend you create some archiving method for the logs, I don't recommend extending the retention to be 3 years, because you will impact the system and run out of space, that also means you will need some separate file storage and a different way to read through the content.
If you are already at this time looking for info from 3 years ago, that unfortunately most likely doesn't exist anymore.
PaiChung
22-Sapphire I
(To:Sid_Del)
Sid_Del
(To:PaiChung)
Hi Pai,
Thanks for sharing default storage time of change history. Unfortunately, my case was different where we need to troubleshoot who created those parameters 3 years back and we don't have any information on that.
Sid
nmutter
(To:Sid_Del)
Call service GetConfigurationChangeHistory on the thing manually and show it in a mashup or whatever. The Composer does not show all results of the service.
Hopefully it helps!
Hello Sid,
Just to add to @nmutter's reply, for a wider range of configuration changes (including entity deletion, for example) consider configuring Audit Subsystem. It will even handle long-term archiving for you.
/ Constantine
