How to get entity basetype?
fmanniti
Is it possible to determine what a entity is?
I will explain myself:
I would like to make a service which has both as input and output a string.
I insert the name of a entity and it returns
"This entity is a Thing"
"This entity is a Data shape"
"This entity is a username"
Is this possible?
aseaton
(To:fmanniti)
Hi Fabio,
Here is the solution for your question.
Hope it helps!
Andy
9 REPLIES 9
aseaton
(To:fmanniti)
Hi Fabio,
Hope it helps!
Andy
Thank you!
That's my method
function getEntityDescription(myEntityName) {
    var collectionName = 'Things';
    var entityType ='Thing';
    var isThing = true;
    var isThingTemplate = false;
    var isThingShape = false;
    var isDataShape = false;
    var isModelTag = false;
    var isNetwork = false;
    var isDataTag = false;
    var isOrganization = false;
    var entity = Things[myEntityName];
    if (entity==null) {
        isThing = false;
        entity = ThingTemplates[myEntityName];
        isThingTemplate=true;
        collectionName = 'ThingTemplates';
        entityType = 'ThingTemplate';
    if (entity==null) {
        isThingTemplate=false;
        entity = ThingShapes[myEntityName];
        isThingShape = true;
        collectionName = 'ThingShapes';
        entityType = 'ThingShape';
    if (entity==null) {
        isThingShape=false;
        entity = DataShapes[myEntityName];
        isDataShape = true;
        collectionName = 'DataShapes';
        entityType = 'DataShape';
    if (entity==null) {
        isDataShape=false;
        entity = ModelTags[myEntityName];
        isModelTag = true;
        collectionName = 'ModelTags';
        entityType = 'ModelTagVocabulary';
    if (entity==null) {
        isModelTag=false;
        entity = Networks[myEntityName];
        isNetwork = true;
        collectionName = 'Networks';
        entityType = 'Network';
    if (entity==null) {
        isNetwork=false;
        entity = DataTags[myEntityName];
        isDataTag = true;
        collectionName = 'DataTags';
        entityType = 'DataTagVocabulary';
    if (entity==null) {
        isDataTags=false;
        entity = Organizations[myEntityName];
        isOrganization = true;
        collectionName = 'Organizations';
        entityType = 'Organitzation';
     return {
        entity: entity,
        isThingShape: isThingShape,
        isThing: isThing,
        isThingTemplate: isThingTemplate,
        isDataShape: isDataShape,
    isModelTag: isModelTag,
    isNetwork: isNetwork,
    isDataTag: isDataTag,
    isOrganization: isOrganization,
        collectionName: collectionName,
        type: entityType
Would be good to know which method it's faster...
Ok I did some tests,
Iterating 1000 times over both functions, my method last at max 10ms ( for 1000 iterations ), the SearchModelEntities method lasts for 15000ms ...
Oh, that's a great point.
Even because your method was quite similar to mine.
I have this input which can be Username, Thing, ThingTemplate.
My metod was
var isUser = (Users[myInput]) ? true : false;
var isThing = (Things[myInput]) ? true : false;
var isTemplate = (ThingTemplates[myInput]) ? true : false;
so, tecnically, it's even faster since it has to choose between three.
I just asked because I believed it was not too orthodox
Your are good to go with you method.
With Search method you must use Search resources, with ModelEntityCollection[] method you are working with In-Memory objects, that's why it's a way faster.
One second, your solution Fabio has a problem, look at my General Performance Recommendations and some perks (unofficial) document.
You should check always explicit --> (Users[myInput])? true : false; should be (Users[myInput]!==null)
and so on.
Oh, ok. Thanks!
