How to get kepware timezone in Thingworx
SOLVED
Highlighted
Amethyst
My scenario is that my kepserver is in local timezone and Thingworx instance is in UTC timezone. How can I get the difference between the timezone in Thingworx so that I can convert the date time in machine timezone itself.
With regards
Yedukrishnan U
Tags (2)
1 ACCEPTED SOLUTION
Re: How to get kepware timezone in Thingworx
HI @slangley ,
We were able to retrieve local timezone of kepware through system tags which will not change based on Thingworx server timezone. We started logging those data and able to capture local timezone.
With regards
Yedukrishnan
4 REPLIES 4
Hi @Yedukrishnan.
In discussing this with the Kepware support team, I was advised that the timestamp in all interfaces is sent from Kepware as UTC.  If the ThingWorx instance is already in UTC, not sure what problem you're running into.  Can you provide an example of what you're seeing?
--Sharon
Hi @Yedukrishnan.
If you still have questions on this, please let us know.  Otherwise, it the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
HI @slangley ,
With regards
Yedukrishnan
Hi @Yedukrishnan.
That's good to hear.  For the benefit of others on the community, please mark the appropriate response as the Accepted Solution.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
