Hi All,
Is it possible to list the datashape names that are existed in thingworx.
Hello!
Does the following help?
ThingWorx Composer --> System --> Resources --> open "EntityServices" --> go to "Services" --> test "GetEntityList" --> enter "DataShape" in the field "type"
I have just tested it and I get as result the list of all available DataShapes on my ThingWorx. If you are interested only in the DataShape Name, you might want to create your own Service that uses this GetEntityList and provides only the DataShape Names.
I hope that helps!
Best Regards,
Vanessa
Hello!
I hope that helps!
Best Regards,
Vanessa
