I want to assign the mashup loaded event to the service after invoking it. Is there any possibility to do like this.
Thanks in advance.
You will need to use the Service Invoke Completed Event and wire that back to the events that the Mashup loaded fires off.
Does that mean you want to again invoke the service after its completion , and that on a mashup load ?
