How to have the groups in dashboard widget be in a collapsed default state?
MFritzhand
7-Bedrock
Hello all,
Currently the default for Dashboard Widget - is that the groups are expanded. I would like them to be collapsed in size for when I view the mashup.
In the attached files below you can see how the groups are defaulted to being expanded. In the second picture, I collapsed each individual group - that is what I would like it to be looking like.
Any direction would be great - thank you!
6 REPLIES 6
PaiChung
22-Sapphire I
(To:MFritzhand)
Isn't expand collapse bindable? You could set them with a service. not that pretty on load perhaps
There is no Dashboard widget property for expand and collapsing the groups. What do you mean exactly? Thank you!
PaiChung
22-Sapphire I
(To:MFritzhand)
ah if it doesn't exist that's a bummer.
Don't think there is a way then to do it with dashboards, you could do it (but a lot of extra work) with the collection widget.
I'll have to look further into Collection Widget- seems a bit confusing compared to Dashboard widget! Thank you!
Hello @MFritzhand
It seems that there are no attributes to control the default behavior.
During my investigation, I found that this behavior is controlled by DIV CSS, maybe it can be solved by customizing DIV CSS.
You can investigate more deeply, refer to help center
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Mashup_Builder/Mashups/MashupCustomCSS.html
I hope this information can help you.
BR,
Max
slangley
(To:MFritzhand)
Hi @MFritzhand.
If you feel that one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
