I've used a state definition already using a different dependent field. So i can't apply for differrent field
How can i highlight the row in grid based on DateDifference using css
Hello @Keerthivarman ,
Pls share the ThingWorx version you are using. Also check the following article for your reference:
https://www.ptc.com/en/support/article/CS280979
Also, there is a community post which resolved the similar issue:
Let me know if this doesnt help you.
Regards
Bhawna
