How to identify the user who invoked the service?
One option I'm aware of is based on the appKey
var loggedInUser = Resources["CurrentSessionInfo"].GetCurrentUser();
with this approach, I had to create an appKey for each user.
What other options are available? If i didn't want to generate a new appKey for every user.
Regards
Arunkumar D
Nope.
If we invoke the service using appKey, GetCurrentUser() would give the user associated with that appKey.
Anyway, one another approach I found to identify the user is to use Authorization header. Like below:
curl -X POST -u username:password -H "Accept:application/json" -H "Content-Type:application/json" "http://hostname/Thingworx/Things/TestThing/Services/TestAPI"
I find this approach would fit me for now, instead of creating an appKey for every user.
Regards
Arunkumar D
Resources["CurrentSessionInfo"].GetCurrentUser() doesn't depend on appkeys; it returns whoever the current user is.
Nope.
Regards
Arunkumar D
