How to import google map location data from database
tguo
Hi all,
    I have a problem on how to import google map location data from database.
    The longitude, latitude, elevation are stored in different column in the postgresql database. I want to connect the database to the google map widget.
    How can I do this?
    BTW:
    I know how to insert location data through Thing->Services (javascript) and extract location data also through Thing->Services to a datashape and bind the datashape to the google map. But now the location data will from columns of database? I am a little confusing.
1 ACCEPTED SOLUTION
ankigupta
(To:tguo)
Hi Tiantian Guo​,
Please try something like:
// result: INFOTABLE  dataShapeName : "MapData"
var result = Things["DBThing"].Service1(); // Change the ThingName and Service name here
var newField = new Object();
newField.name = "buildinglocation";
newField.baseType = 'LOCATION';
result.AddField(newField);
// location:LOCATION
var location = new Object();
var tableLength = result.rows.length;
for (var x = 0; x < tableLength; x++) {
var row = result.rows;
    location.latitude = row.latitude;
    location.longitude = row.longitude;
    location.elevation = 0;
    location.units = "WGS84";
    result.rows.buildinglocation = location;
I hope it helps.
15 REPLIES 15
ankigupta
(To:tguo)
Hi Tiantian Guo​,
Per my understanding; this will require conversion of longitude, latitude, elevation data to a Location Object.
Steps:
1. Read longitude, latitude, elevation Data from DataBase in an infotable.
2. Loop through the Table and convert longitude, latitude, elevation data to Location Object infotable. Example:
location.latitude = latitudeFromDataBase;
location.longitude = longitudeFromDataBase;
location.elevation = elevationFromDataBase;
3. Bind the new infotable to the Google widget.
I hope it helps.
tguo
(To:ankigupta)
Thanks Ankit. I am now doing like this.
But I now want to get a new column "location" from other three columns. I found some solutions. The grammar for thingworx needs to get used to..
Currently my code is like:
var params = {
infoTableName : "MapDataWithLocation",
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(MapData)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var buildinglocation = new Object();
buildinglocation.name = "buildinglocation";
buildinglocation.baseType = 'location';
result
got some errors.. still working..
tguo
(To:ankigupta)
And some loop like this:
for (i = 0; i < result.getRowCount(); i++) {
    myfield.latitude = result.getRow(i).latitude;
    myfield.longitude = result.getRow(i).longitude;
    myfield.elevation = 0;
    myfield.units ="WGS84";
    result.getRow(i).buildinglocation = myfield;
tguo
(To:tguo)
Finally the code is no bug:
var params = {
var row = yourInfotableHere.rows;
//Your code here
    row.buildinglocation.latitude = row.latitude;
    row.buildinglocation.longitude = row.longitude;
    row.buildinglocation.elevation = 0;
    row.buildinglocation.units ="WGS84";
My input is a datashape.
The datashape is a output from the database.
But this code output is just fields of a new datashape. Where I get the data?... Really a newbie, sorry and thanks!
ankigupta
(To:tguo)
Hi Tiantian Guo​,
I hope it helps.
tguo
(To:ankigupta)
Dear Ankit,
      It is really helpful. I think I start to understand the thingworx function now..
      I change your code like this:
var result = Things["ExtractData"].extractdata(); // Change the ThingName and Service name here
newField.name = "location";
var temp = new Object();
temp.baseType = 'LOCATION';
    temp.latitude = row.latitude;
    temp.longitude = row.longitude;
    temp.elevation = 0;
    temp.units = "WGS84";
    result.rows.location = temp;
But the output like this:
something wrong here. But it really a big step for me. Thanks!
tguo
(To:tguo)
I think I get it. The result I get from table is "double". I need to convert it to double. Trying
tguo
(To:ankigupta)
Error like this:
really last step. I am trying.
ankigupta
(To:tguo)
Hi Tiantian Guo​,
Could you please share the MapData DataShape here. Try changing the Datatype of latitude and longitude to number.
I have tried the code on my system and it works fine.
Also, I hope you have set the DataShape in the ExtractData DataShape.
I hope it helps.
tguo
(To:ankigupta)
Dear Ankit,
My code is finally like this and compiled successfully:
var result = Things["EThingName"].ServicesName(); // Change the ThingName and Service name here
temp.latitude = "";
temp.longitude = "";
temp.elevation = "";
temp.baseType = "LOCATION";
    temp.latitude = row.latitude;//result.rows.latitude;
    temp.longitude = row.longitude;//result.rows.longitude;
    temp.elevation = 0;
    row.location = temp;
But the output is like:
Something is wrong but no idea.
Any other thingworx masters have solutions on this?
Thanks!!
ankigupta
(To:tguo)
Could you please share Screenshot of fields in MapData DataShape.
tguo
(To:ankigupta)
The MapData datashape is no problem. I think..
yshen-2
(To:tguo)
Pleas move
inside for loop
other wise you are setting all the location field to one object and do the change on one object
YUanwu Shen
supandey
(To:tguo)
Ankit Gupta​ I see this thread has already been answered and Tiantian Guo​ has opened another for issue on NaN could you please have following discussion on that thread i.e. How to solve the NaN value in updated location field
Sushant
ankigupta
(To:supandey)
Sushant Pandey​ Sure!
