How to log specific user activity
Level 1
1. I wondered how can I log specific user name activity - save in known stream, lets assume the activity is logged in the Application log.
2. I created new appKey and assigned specific user to it, this appKey is used for executing rest call, I can see the request in the application log, for example:
Executing request [URI: /Thingworx/Things/myThing/Properties/Property1]
I want to save this row in a specific know stream, how is it possible?
3 REPLIES 3
Re: How to log specific user activity
In the security log if you set the level low enough, you can see all requests by any users.
it is a bit dangerous because it can overload your logs and then the system potentially.
You could also add some services on each mashup and on each executed service that write to a stream
Hi Pai,
Thanks for the information but you are not answering my question
Highlighted
What are the different activities logged for user and for each user what are the details(like username, IP address,CRUD operations on entities,services used etc..)
