How to make a table without data shape in JavaScript
  • April 20, 2022
  • 967 views
I need to be able to make a table through which, if there is changes in data, the no of rows and columns should be flexible enough to change, which currently is not possible if you create a table via data shapes.
I wish to know if it is possible to create a table which has flexible of no of rows.
Best answer by PaiChung
You can use the 'addField' to add columns to an infotable (as well as removeField) to suite your needs.
PaiChung22-Sapphire IAnswer
22-Sapphire I
April 20, 2022
