Hello @Vipul_Oswal,
Let me clarify it a little bit:
Regular thing: Javascript Service:
let jsonString = InfoTable.toJSON();
let stringArray = jsonString.rows;
Things["YourDatabaseThing"].UpdateDataBaseWithJSON({
StringArray: stringArray
SQL thing: SQL Command Service:
exec [StoredProcedure] @json = [[StringArray]]
Example Stored Procedure:
ALTER procedure [dbo].[_InsertPersonData]
@json NVARCHAR(max)
as
begin
MERGE INTO [User] AS target
USING (
SELECT
distinct PersonnelNumber, FirstName, LastName, PlantUID
FROM OPENJSON(@json, '$.rows')
WITH (
OrgID NVARCHAR(256) '$.OrgID',
PersonnelNumber NVARCHAR(256) '$.PersonnelNumber',
FirstName NVARCHAR(256) '$.FirstName',
UserRole NVARCHAR(256) '$.UserRole',
IsHybridArea bit '$.IsHybridArea',
UserOrgType NVARCHAR(256) '$.UserOrgType',
OrgName NVARCHAR(256) '$.OrgName',
LastName NVARCHAR(256) '$.LastName',
PlantUID NVARCHAR(256) '$.PlantUID',
CostCenterID NVARCHAR(256) '$.CostCenterID'
) AS source
ON target.personid = source.PersonnelNumber
WHEN MATCHED THEN
UPDATE SET
plantuid = source.PlantUID,
firstname = source.FirstName,
lastname = source.LastName,
isactive = '1',
updatedby = 'System User',
updateddate = getdate(),
shiftuid = '1',
WHEN NOT MATCHED THEN
INSERT (plantuid,personid,firstname,lastname,roleuid,isactive,shiftuid,createdby,createddate)
VALUES (source.PlantUID, source.PersonnelNumber, source.FirstName, source.LastName,'7','1','1','System User',getdate())
WHEN NOT MATCHED BY SOURCE THEN
UPDATE SET target.isactive = 0;
end
Your stored procedure might look different as you are using MySQL.
Jens
