Can someone provide an example of using GetNamedProperties and GetNamedPropertyValues from Javascript? The first call takes a JSON object, and the second takes an INFOTABLE, but I haven't been able to find any documentation on what that JSON object or INFOTABLE should look like ...
Thanks !
Hi Shaun,
The JSON object GetNamedProperties() takes as input (propertyNames) consists of a single JSON array (items):
var propertyNames = { "items": ["name", "stringProperty", "numberProperty"] }
var propertyValues = Things["ExampleThing"].GetNamedProperties({ propertyNames: propertyNames })
Similarly, GetNamedPropertyValues() is expecting an InfoTable with a DataShape of EntityList:
var propertyNames = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({ dataShapeName: "EntityList" })
propertyNames.AddRow({ name: "name" })
propertyNames.AddRow({ name: "stringProperty" })
propertyNames.AddRow({ name: "numberProperty" })
var propertyValues = Things["ExampleThing"].GetNamedPropertyValues({ propertyNames: propertyNames })
Hi Shaun,
Thanks Adam - I will give this a try !!
