We are having a mashup showing grid column. The numeric values in grid are hyperlinked(using <a href=""></a> tag of HTML in thingworx service) to show a new mashup from it.On click on the numeric value, the new mashup opens but it asks for thingworx user credentials the first time. In order to prevent the same we are planning to pass application key along with the url in hyperlink. But the url including the appkey will be displayed in the mashup url, please let us know if there is any other option to prevent entering the credentials.
I'm not totally confident this is possible, but what you need is to establish a client side session before hand.
So potentially invoking a url 'silently' with the session switch to true and the appkey might do the trick
sorry never actually done it, so you may have to experiment.
maybe do it with a hidden webframe widget if it has to be a mashup
Please note that any of these client side methods will be visible if someone has the developer tool open.
the proper secure way would be to use SSO or to make them login
Hi Pai,
Thanks for the response. Our requirement is to open a mashup on clicking a cell in grid (selected row will not suffice, we want a particular cell only). For the same we have made the cells as html links (which points to a mashup) programatically. But since this mashup is already loaded from a Formlogin page, we don't want to enable login once more on clicking the cell of the grid. Can you suggest any other options that would help us here. As you mentioned appkey passing on the link might not be a good option.
