How to read Texts from images in thingworx and send to thingworx database?
Suraj_Patil
How to read Texts from images in thingworx? is there any direct functionality to read texts?
is there any extension available for this?
i have this link but for this need to install thingworx flow
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/Azure/ComputerVision.html
without thingworx flow how to get this done?
Rocko
(To:Suraj_Patil)
I agree with Pai. You can use ContentLoader services and push the image to Azure Cognitive Services with a REST POST request:
https://learn.microsoft.com/en-us/rest/api/computervision/image-analysis/analyze-image?view=rest-computervision-v4.0-preview+%282023-04-01%29&tabs=HTTP&tryIt=true&source=docs#code-try-0
Handling the authentication is probably the most complex part of it.
The alternative "old-fashioned" approach would be to get an offline OCR software, commercial or open-source, and write a TWX extension that passes over the data.
PaiChung
22-Sapphire I
(To:Suraj_Patil)
Azure Computer Vision or other such programs can help read the text.
You probably can just integrate to it using REST API vs. using TWX Flow
From what I understand TWX Flow might be discontinued (still not 100% decided I think)
yes i understand thingworx flow can be useful but apart from that is there is any other options to get it done?
PaiChung
22-Sapphire I
(To:Suraj_Patil)
Sorry you should use a third party program like Azure Computer Vision.
You can integrate using REST API instead of using TWX Flow
Rocko
(To:Suraj_Patil)
