hey everyone,
I am currently working with the drop-down-list-widget. The list-widget contains a few strings and everytime I select a string in the list-widget, I want to use
this string to do further work. But it seems that there is no binding option for retrieving this string.
Is it somehow possible to retrieve the text of the current selected item?
Thank you in advance!
Best regards,
Theresa
The selected text is available from Selected Row(s)->Property_Name of Service feeding the DropDownList. I am referring to the service available in the Right Panel.
