How to return MAX() from a specific field in Data Table?
chrish
I'm trying to create a service that I can globally put in a ThingShape; then reference inside every new DataTable that I create. This service will find the PK of each new data table and ensure that it is populated with a unique/increasing value. To do this, I need to be able to find the current MAX() value of all data in the data table for the PK field; then set new row PK field to MAX()+1.
If I'm simply way out in left field...please reign me in, but I think I'm close.
Please provide a sample script for how to query this information from an existing data table.
PaiChung
22-Sapphire I
(To:chrish)
So to find out what Aggregate puts out, you can always first set the result to the Aggregate (basetype infotable) and see the result in Composer.
Aggregate pre-pends the operation before the field it is acting upon.
So newID = dtMax.MAX_KEY_Field
5 REPLIES 5
PaiChung
22-Sapphire I
(To:chrish)
The Aggregate service can give you MAX (as well as MIN COUNT AVERAGE SUM)
chrish
(To:PaiChung)
Ok, almost there!  dtMax variable is a INFOTABLE with exactly 1 row and 1 column. How do I set the variable "newID" to the single numeric value of dtMax?
    var dtParams = { maxItems: undefined /* NUMBER */  };
    var dtValues = me.GetDataTableEntries(dtParams); //INFOTABLE
    var newID=0 // NUMBER
    var dtMaxParams = {
        t: dtValues, // INFOTABLE
        columns: KEY_Field, // STRING
        aggregates: "MAX", // STRING
        groupByColumns: undefined // STRING
    var dtMax = Resources["InfoTableFunctions"].Aggregate(dtMaxParams); //INFOTABLE
    newID = ????
PaiChung
22-Sapphire I
(To:chrish)
chrish
(To:PaiChung)
Thanks Pai! I combined this with the service I referenced in:
How to use variable in "VALUES.<COLUMN>" as the <COLUMN>? (i.e. VALUES.variable=1)
I've built a really cool ThingShape to implement on all new DataTables that is really going to streamline maintenance.  Thanks again!
I am unable to use aggregation for sum or max or min value calculations.
Here is my code:
var params = {
path: "test_aggrigation.csv" /* STRING */,
columnMappings: undefined /* STRING */,
hasHeader: undefined /* BOOLEAN */,
longitudeField: undefined /* NUMBER */,
dateFormat: undefined /* STRING */,
fileRepository: "FileStorageThing" /* THINGNAME */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: undefined /* STRING */,
stringDelimiter: undefined /* STRING */,
dataShape: "aggrigateShape" /* DATASHAPENAME */
// result: INFOTABLE
var data = Resources["CSVParserFunctions"].ReadCSVFile(params);
logger.warn(data);
//Aggregate code start from here..
var result = Resources["InfoTableFunctions"].Aggregate({
t: data,
columns: "temp_min",
aggregates: "SUM",
groupByColumns: "temp_max,date"
ERROR Code:
Error executing service:
Error executing service calculateMin. Message :: java.lang.String cannot be cast to java.lang.Number - See Script Error Log for more details.
Can you please help me on this?
Regards
Vikas
