when an alert is triggered, the instant value of that property should be passed to a web service through a json.
Hi Priyanshi, you can try the following steps to achieve what you are looking for :
3. Create a subscription with Event -> Alert and select the Property on which the Alert will be fired and you would call this service created in above step (Step 2)
Hope this helps.
How to get the value of a property at that very instance when the alert is triggered. Please could you provide some sample code for the script to get the current value from property in json form
