Hi
I am trying to get the feed example working (www.thingworx.com/feed). I am able to get to feed through my datashape service code when I am not connected with my corporate Network. However the moment I get connected within the corporate network I am unable to hit the feed URL from my codebase, - giving me a hostnotfoundexception.
Please let me know how to setup proxy to go outside the firewall in Thingworx.
Thanks & Regards
Prasanna
The example uses http://www.thingworx.com/feed as the source for the data, please try this link from the browser directly both within and outside the corporate network. If it does not return data directly then it's likely a IT/security issue that must be resolved.
The above URL does work from the browser. It just does not seem to be working from within the application. Hence the request for setting proxy from within the application. Please let me know incase you need further clarification on the question and I will be glad to explain.
Thanks & Regards
Prasanna kumar
