How to show single series in bar chart
RK_0705
Hi Team,
Suppose, my service is returning 1 String field and 2 Integer fields.
The string field will take the X-axis but want to show only 1 series in Y axis out of those two integer fields.
How to achieve this behaviour as there is no flexibility to select Y axis field in properties.
The All data is binded to Data property of Bar chart widget. Thingworx version is 9.0
Please help.
Thanks in advance.
3 REPLIES 3
PaiChung
22-Sapphire I
(To:RK_0705)
Maybe use the 'Stack Bar'?
Else in the service returning the data, resolve those two columns into a single column?
eferent
(To:PaiChung)
It seems this has been deprecated?
slangley
(To:RK_0705)
Hi @RK_0705.
Was the previous response helpful in finding a solution?  If so, please mark it as the Accepted Solution for the benefit of others in the community.
If you're still searching for a solution, please let us know.
--Sharon
