This is a recent learning task of mine. The teacher hopes that we can simulate the movement trajectory of a conveyor belt in real time. I hope someone can help me.
We've done overlapping shapes before to do this.
This is very vague.
I would encourage you to first write down the requirements of what it would look like.
What is movement trajectory, what defines a movement.
After that I think you should probably notice what you need to fill in next and that should get you to the start of your simulation needs.
Thanks.
I have a slider that moves along a fixed path and can read his distance information. I want to know how to simulate his movement in the mashup, so as to observe his movement more intuitively.
(NB. never tried to move elements only changed colour and text values in a svg-image.)
I assume that this is a 2D picture where you present the location.
Have a look at the SVG-widget and use overrides to move an element describing the thing you want to track.
Good luck
Per
