Hi all,
I am now using File Repository Thing template to get ftp file info, and one of its service is called "GetFileListingWithLinks".
The result is an infotable, but I dont know how to sort the result by LastModifiedTime, which is one of the columns in the result table. (Cannot see/modified the code inside..).
I hope to get the latest File Info, so hope someone can help.
Thanks!
Hi Xiaoying, if the service you are using has the option to include Query parameter you can consider including the Sort option, this is covered in the Help documentation you can check here
Hi.
I think "sorts" parameter must be inside "filter" parameter, which contains also "filters" parameter...
So something like this:
filter: { "sorts": [ { "fieldName": "UID", "isAscending": false } ], "filters": { "fieldName": "Name", "type": "EQ", "value": "myNameValue" } }
Sébastien
Alternatively you can use also Sort snippets, there's two:
// Option 1 - In-place
myInfotable.Sort({ name: "fieldName", ascending: true/false });
// Option 2 - New Sorted Infortable
var myInfotableSorted = Resources["InfoTableFunctions"].Sort({
t: myInfotable,
sortColumn: "fieldName",
