How to unselect the value in list widget
akully
I am using list widget to select values,I want to use list widget in such a way that I will be able to deselect the selected values from list at runtime.
ankigupta
(To:akully)
Hi Amruta Kully​,
You can reload the page on click of button to clear the selection.
I hope it helps.
Ok.I will try.
ankigupta
(To:akully)
Hi Amruta Kully​,
You can use expression widget and put location.reload() in the expression parameter of the Widget. Link the click event of Button to evaluate function of expression widget to reload the Mashup on click of Button.
