How to upgrade "Windchill Extension for ThingWorx" on Windchill server while upgrading Windchill 11 M010 to Windchill 11 M020
vshanmugavelayu
11-Garnet
I have upgraded the Windchill server from Windchill 11 M010 to Windchill 11 M020 build. I want to know if there are any specific steps to be followed before installing "Windchill Extension for ThingWorx" (11.0-M020_WCTWXExtension-07.07) to uninstall the older "Windchill Extension for ThingWorx" (11.0-M010_WCTWXExtension-07.05)?
Please refer to the following document: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS192818&lang=en_US
Importing a Newer Version of an Extension - Upgrading
  • If changing the major version number do the following:
    1. Export all of the dependent entities for the current version of Extension (Tags will help with this process)
    2. Remove the existing current extension using the Extension Manager under the Import/Export menu option in Composer
    3. Restart the ThingWorx instance (via Tomcat)
    4. Import the new version of the Extension
    5. Import the Entities
  • If only changing the minor or patch version number an in-place upgrade is applicable and the extension can be imported into ThingWorx with the prior version still in place
3 REPLIES 3
Thanks Polish,
how about the update on windchill Side? Is there any step to uninstall the previous build patch before installing the new version patch?
I would refer to the windchill documentation (I'm on the Thingworx side), but since this is a patch, I'm assuming you wouldn't need to uninstall the previous one.
