I noticed that there is a field called MenuData in Menu Widgets.
It's obviously need to be attach an InfoTable type output.
Do you know how to use it?
Similar to your other post, https://www.ptc.com/en/support/article/CS282462 gives an example to use this.
Christophe
Christophe
Hi @JasonKwan987.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
