How to use MenuData fields in Menu Widgets?
JasonKwan987
8-Gravel
I noticed that there is a field called MenuData in Menu Widgets.
It's obviously need to be attach an InfoTable type output.
Do you know how to use it?
1 ACCEPTED SOLUTION
cmorfin
(To:JasonKwan987)
Hi @JasonKwan987
Similar to your other post, https://www.ptc.com/en/support/article/CS282462 gives an example to use this.
Christophe
cmorfin
(To:JasonKwan987)
Hi @JasonKwan987
Christophe
slangley
23-Emerald II
(To:JasonKwan987)
Hi @JasonKwan987.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
