Hi all,
Does anyone know how to use google maps libraries like drawing library , geometry library and places library in google maps widget in thingworx ?
There is a section of the Custom Extension Development Guide that talks about using custom widgets, and about using third party libraries in custom widgets.
Hope this helps!
On the metadata.xml you can replace:
<FileResource description="" isRuntime="true" isDevelopment="false" type="JS" url="https://maps.google.com/maps/api/js?sensor=false"/>
By:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?sensor=false&libraries=drawing,geometry"
description="" isDevelopment="false" isRuntime="true" />
I hope this can help you.
Hi Ana,
Thanks for your help.
I have updated the metadata.xml file as you said.
But how to use that in the map ? I am unable to use it .
I added another data source to save the shapes and i call the function that i use to add the drawing option at the updateProperty.
But I think that you can added the code that you need at the afterRender, after having the map:
this.map = new google.maps.Map(document.getElementById(this.jqElementId), options);
var polyOptions = {
strokeOpacity: 0.9,
strokeWeight: 2,
strokeColor: zoneColor,
fillOpacity: 0.50,
fillColor: zoneColor,
editable: true,
draggable: true
drawingManager = new google.maps.drawing.DrawingManager({
drawingControl: true,
drawingControlOptions: {
position: google.maps.ControlPosition.TOP_CENTER,
drawingModes: [
google.maps.drawing.OverlayType.CIRCLE,
google.maps.drawing.OverlayType.POLYGON
polygonOptions: polyOptions,
circleOptions: polyOptions
drawingManager.setMap(this.map);
drawingManager is declared as global variable.
For my case, i just want to give the option to draw polygons and circles.
This is only for drawing the shapes.
I hope this can help you,
Regards.
drawingManager
Hi Ana,
I tried the above steps as you said but still I can't see the drawing options available at the top of the map.
Can you please help regarding this ?
Of course, can you send me your code please?
TW.Runtime.Widgets.googlemap = function () {
var infoWindow = undefined;
var drawingManager = undefined;
var userHasPannedOrZoomedSinceAutoZoom = false;
var initialData = true;
var weAreChangingBounds = false;
var autoZoomBehavior = 'every-data-change';
var regionInfoWindow = undefined;
var lastRegionNumber = undefined;
var lastData = undefined;
var lastRegionData = undefined;
var infoId = 'MapInfoWindow' + TW.uniqueId();
var tooltipMashupWidth = 100;
var tooltipMashupHeight = 100;
var isMashupTooltipConfigured = false;
var isRegionTooltipConfigured = false;
var dataInfotable = undefined;
this.runtimeProperties = function () {
return {
'supportsAutoResize': true,
'needsDataLoadingAndError': true,
'propertyAttributes': {
'TooltipLabel1': {'isLocalizable': true},
'TooltipLabel2': {'isLocalizable': true},
'TooltipLabel3': {'isLocalizable': true},
'TooltipLabel4': {'isLocalizable': true},
'RegionTooltipLabel1': {'isLocalizable': true},
'RegionTooltipLabel2': {'isLocalizable': true},
'RegionTooltipLabel3': {'isLocalizable': true},
'RegionTooltipLabel4': {'isLocalizable': true}
this.resize = function(width,height) {
try {
google.maps.event.trigger(this.map, 'resize');
} catch(err) {}
this.renderHtml = function () {
tooltipMashupWidth = thisWidget.getProperty('TooltipMashupWidth');
tooltipMashupHeight = thisWidget.getProperty('TooltipMashupHeight');
var oldAutoZoom = this.getProperty('AutoZoom');
autoZoomBehavior = this.getProperty('AutoZoomBehavior');
switch( autoZoomBehavior ) {
case 'disable-on-user-pan-zoom':
case 'only-when-autozoom-invoked':
case 'only-initial-data':
// leave these alone
break;
default:
// anything else, default to our old behavior
if( oldAutoZoom === undefined || oldAutoZoom === true ) {
} else if( oldAutoZoom === false ) {
autoZoomBehavior = 'only-when-autozoom-invoked';
} else {
break;
var mashupName = thisWidget.getProperty('TooltipMashupName');
if (mashupName !== undefined && mashupName.length > 0) {
isMashupTooltipConfigured = true;
try {
if (google !== undefined && google !== null) {
this.haveGoogleMaps = true;
catch (errmsg) {
if (this.haveGoogleMaps)
return '<div class="widget-content widget-map-runtime"></div>';
else
return '<div class="widget-content widget-map-runtime"><span class="textsize-large">Google Maps Are Not Available</span></div>';
var thisWidget = this;
this.haveGoogleMaps = false;
this.ignoreSelectionEvent = false;
this.ignoreRegionSelectionEvent = false;
this.map = undefined;
this.selectionMarker = null;
this.startMarker = null;
this.endMarker = null;
this.polyline = null;
this.routePolyline = null;
this.plannedRoutePolyline = null;
this.dataBounds;
this.plannedRouteDataBounds;
this.routeDataBounds;
this.regionDataBounds;
this.lastBounds;
this.lastZoom;
this.markerLookup = new Array();
this.currentMarkers = new Array();
this.selectedRows = new Array();
this.currentRegions = new Array();
this.selectedRegionRows = new Array();
this.markerStyle;
this.selectedMarkerStyle;
this.selectionMarkerStyle;
this.startMarkerStyle;
this.endMarkerStyle;
this.pathStyle;
this.routeStyle;
this.plannedRouteStyle;
this.regionStyle;
this.afterRender = function () {
this.markerStyle = TW.getStyleFromStyleDefinition(this.getProperty('MarkerStyle'));
this.selectionMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectionMarkerStyle'));
this.selectedMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedMarkerStyle'));
this.startMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('StartMarkerStyle'));
this.endMarkerStyle = TW.getStyleFromStyleDefinition(this.getProperty('EndMarkerStyle'));
this.pathStyle = TW.getStyleFromStyleDefinition(this.getProperty('PathStyle'));
this.plannedRouteStyle = TW.getStyleFromStyleDefinition(this.getProperty('PlannedRouteStyle'));
this.routeStyle = TW.getStyleFromStyleDefinition(this.getProperty('RouteStyle'));
this.regionStyle = TW.getStyleFromStyleDefinition(this.getProperty('RegionStyle'));
this.selectedRegionStyle = TW.getStyleFromStyleDefinition(this.getProperty('SelectedRegionStyle'));
if (this.haveGoogleMaps) {
var zoom = parseInt(this.getProperty('Zoom'));
var centerPosition = new google.maps.LatLng(TW.clientPosition.coords.latitude, TW.clientPosition.coords.longitude);
if (this.getProperty('SelectedLocation') !== undefined) {
centerPosition = new google.maps.LatLng(this.getProperty('SelectedLocation').latitude, this.getProperty('SelectedLocation').longitude);
var options = {
zoom: zoom,
center: centerPosition,
mapTypeId: this.getProperty('MapType')
switch( this.getProperty('MapSkin','normal') ) {
case 'normal':
break;
case 'blue':
options['styles'] = [{"featureType":"water","elementType":"geometry","stylers":[{"color":"#193341"}]},{"featureType":"landscape","elementType":"geometry","stylers":[{"color":"#2c5a71"}]},{"featureType":"road","elementType":"geometry","stylers":[{"color":"#29768a"},{"lightness":-37}]},{"featureType":"poi","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"featureType":"transit","elementType":"geometry","stylers":[{"color":"#406d80"}]},{"elementType":"labels.text.stroke","stylers":[{"visibility":"on"},{"color":"#3e606f"},{"weight":2},{"gamma":0.84}]},{"elementType":"labels.text.fill","stylers":[{"color":"#ffffff"}]},{"featureType":"administrative","elementType":"geometry","stylers":[{"weight":0.6},{"color":"#1a3541"}]},{"elementType":"labels.icon","stylers":[{"visibility":"off"}]},{"featureType":"poi.park","elementType":"geometry","stylers":[{"color":"#2c5a71"}]}];
break;
case 'gray':
options['styles'] = [{"featureType":"landscape","stylers":[{"saturation":-100},{"lightness":65},{"visibility":"on"}]},{"featureType":"poi","stylers":[{"saturation":-100},{"lightness":51},{"visibility":"simplified"}]},{"featureType":"road.highway","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"road.arterial","stylers":[{"saturation":-100},{"lightness":30},{"visibility":"on"}]},{"featureType":"road.local","stylers":[{"saturation":-100},{"lightness":40},{"visibility":"on"}]},{"featureType":"transit","stylers":[{"saturation":-100},{"visibility":"simplified"}]},{"featureType":"administrative.province","stylers":[{"visibility":"off"}]},{"featureType":"water","elementType":"labels","stylers":[{"visibility":"on"},{"lightness":-25},{"saturation":-100}]},{"featureType":"water","elementType":"geometry","stylers":[{"hue":"#ffff00"},{"lightness":-25},{"saturation":-97}]}];
break;
if (this.getProperty('EnableLocationSelection')) {
options["disableDoubleClickZoom"] = true;
else {
options["disableDoubleClickZoom"] = false;
//if (TW.Runtime.globalMap === undefined) {
// $('body').append(
// '<div id="global-map" style="top:0px;left:0px;width:200px;height:200px;">' +
// '</div>');
// TW.Runtime.globalMap = new google.maps.Map(document.getElementById('global-map'), options);
//this.map = TW.Runtime.globalMap;
//this.jqElement.append($('#global-map'));
//$('#global-map').show().css('height', this.getProperty('Height') + 'px').css('width', this.getProperty('Width') + 'px');
var polyOptions = {
strokeOpacity: 0.9,
strokeWeight: 2,
fillOpacity: 0.50,
editable: true,
draggable: true
drawingModes: [
infoWindow = new google.maps.InfoWindow();
regionInfoWindow = new google.maps.InfoWindow();
if(this.getProperty('ShowTraffic')) {
this.trafficLayer = new google.maps.TrafficLayer();
this.trafficLayer.setMap(this.map);
google.maps.event.addListener(this.map, 'idle', function (event) {
var bounds = thisWidget.map.getBounds();
var changed = false;
if(thisWidget.lastBounds !== undefined) {
if(thisWidget.lastBounds.getNorthEast().lat() != bounds.getNorthEast().lat())
changed = true;
if(thisWidget.lastBounds.getNorthEast().lng() != bounds.getNorthEast().lng())
changed = true;
if(thisWidget.lastBounds.getSouthWest().lat() != bounds.getSouthWest().lat())
changed = true;
if(thisWidget.lastBounds.getSouthWest().lng() != bounds.getSouthWest().lng())
changed = true;
else {
changed = true;
if(changed) {
// ignore this if it's just getting the initial bearings
if( thisWidget.lastBounds !== undefined ) {
if( !weAreChangingBounds ) {
userHasPannedOrZoomedSinceAutoZoom = true;
var nelocation = new Object();
nelocation.units = "WGS84";
nelocation.elevation = 0.0;
nelocation.latitude = bounds.getNorthEast().lat();
nelocation.longitude = bounds.getNorthEast().lng();
thisWidget.setProperty('NEBoundary', nelocation);
var swlocation = new Object();
swlocation.units = "WGS84";
swlocation.elevation = 0.0;
swlocation.latitude = bounds.getSouthWest().lat();
swlocation.longitude = bounds.getSouthWest().lng();
thisWidget.setProperty('SWBoundary', swlocation);
nelocation.latitude = bounds.getSouthWest().lat();
thisWidget.setProperty('SEBoundary', nelocation);
swlocation.latitude = bounds.getNorthEast().lat();
thisWidget.setProperty('NWBoundary', swlocation);
thisWidget.lastBounds = bounds;
thisWidget.jqElement.triggerHandler('BoundsChanged');
var zoomChanged = false;
var currentZoom = thisWidget.map.getZoom();
if(thisWidget.lastZoom !== undefined) {
if(thisWidget.lastZoom != currentZoom)
zooomChanged = true;
else {
zoomChanged = true;
if(zoomChanged) {
thisWidget.setProperty('CurrentZoom', currentZoom);
thisWidget.lastZoom = currentZoom;
if (this.getProperty('ShowSelectionMarker') === true) {
this.selectionMarker = new google.maps.Marker({
map: this.map,
position: centerPosition,
title: "Selection",
icon: this.selectionMarkerStyle.image
this.selectionMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 3);
google.maps.event.addListener(this.map, 'dblclick', function (event) {
var location = new Object();
location.latitude = event.latLng.lat();
location.longitude = event.latLng.lng();
thisWidget.moveSelectionMarker(location);
thisWidget.setProperty('SelectedLocation', location);
thisWidget.jqElement.triggerHandler('Changed');
weAreChangingBounds = true;
this.map.setZoom(this.map.getZoom() - 1);
this.map.setZoom(this.map.getZoom() + 1);
this.moveSelectionMarker = function (newLocation) {
if (newLocation !== undefined) {
var latlng = new google.maps.LatLng(newLocation.latitude, newLocation.longitude);
if (this.selectionMarker !== null) {
this.selectionMarker.setMap(this.map);
this.selectionMarker.setPosition(latlng);
} else {
position: latlng,
map: this.map,
title: "Selection",
this.map.setCenter(latlng);
this.clearSelectedRegions = function () {
thisWidget.selectedRegionRows = [];
for (var regionNo = 0; regionNo < thisWidget.currentRegions.length; regionNo++) {
var currentRegion = thisWidget.currentRegions[regionNo];
currentRegion.setOptions( { fillColor: currentRegion._assignedFillColor, strokeColor : currentRegion._assignedStrokeColor, strokeWeight : currentRegion._assignedStrokeWeight });
currentRegion._isSelected = false;
this.clearSelectedMarkers = function () {
thisWidget.selectedRows = [];
for (var markerNo = 0; markerNo < thisWidget.currentMarkers.length; markerNo++) {
var currentMarker = thisWidget.currentMarkers[markerNo];
currentMarker._isSelected = false;
currentMarker.setIcon(currentMarker._assignedIcon);
currentMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
this.setSelectedMarker = function (selectedRow) {
var isMultiselect = thisWidget.properties['MultiSelect'];
var selectedMarker;
if (currentMarker.rowNumber === selectedRow) {
selectedMarker = currentMarker;
break;
if (selectedMarker !== undefined) {
if (selectedMarker._isSelected) {
if (isMultiselect) {
TW.removeElementFromArray(thisWidget.selectedRows, selectedRow);
selectedMarker._isSelected = false;
selectedMarker.setIcon(selectedMarker._assignedIcon);
selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
if (!thisWidget.ignoreSelectionEvent) {
thisWidget.updateSelection('Data', thisWidget.selectedRows);
else {
if (!isMultiselect) {
thisWidget.clearSelectedMarkers();
thisWidget.selectedRows = [selectedRow];
else
thisWidget.selectedRows.push(selectedRow);
selectedMarker.setIcon(thisWidget.selectedMarkerStyle.image);
selectedMarker._isSelected = true;
selectedMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
this.setSelectedRegion = function (selectedRow) {
var isMultiselect = thisWidget.properties['RegionMultiSelect'];
var selectedRegion;
if (currentRegion.rowNumber === selectedRow) {
selectedRegion = currentRegion;
break;
if (selectedRegion !== undefined) {
if (selectedRegion._isSelected) {
TW.removeElementFromArray(thisWidget.selectedRegionRows, selectedRow);
selectedRegion._isSelected = false;
selectedRegion.setOptions( { fillColor: selectedRegion._assignedFillColor, strokeColor : selectedRegion._assignedStrokeColor, strokeWeight : selectedRegion._assignedStrokeWeight });
if (!thisWidget.ignoreRegionSelectionEvent) {
thisWidget.updateSelection('RegionData', thisWidget.selectedRegionRows);
else {
thisWidget.clearSelectedRegions();
thisWidget.selectedRegionRows = [selectedRow];
else
thisWidget.selectedRegionRows.push(selectedRow);
selectedRegion._isSelected = true;
selectedRegion.setOptions( { fillColor: thisWidget.selectedRegionStyle.backgroundColor, strokeColor : thisWidget.selectedRegionStyle.lineColor, strokeWeight : parseInt(thisWidget.selectedRegionStyle.lineThickness) });
this.handleSelectionUpdate = function (propertyName, selectedRows, selectedRowIndices) {
if (propertyName == "Data") {
thisWidget.ignoreSelectionEvent = true;
var nSelectedRows = selectedRowIndices.length;
for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows;selectedRowIndex++) {
thisWidget.setSelectedMarker(selectedRowIndices[selectedRowIndex]);
thisWidget.ignoreSelectionEvent = false;
if (propertyName == "RegionData") {
thisWidget.ignoreRegionSelectionEvent = true;
thisWidget.setSelectedRegion(selectedRowIndices[selectedRowIndex]);
thisWidget.ignoreRegionSelectionEvent = false;
this.mouseOverEventListener = function (e) {
var latlng = e.latLng;
if (!isMashupTooltipConfigured) {
return;
var markerCount = thisWidget.markerLookup.length;
for (var i = 0; i < markerCount; i++) {
var markerInfo = thisWidget.markerLookup;
if (latlng.lat() == markerInfo.latlng.lat() && latlng.lng() == markerInfo.latlng.lng()) {
var selectedMarker = markerInfo.marker;
var selectedRowNo = selectedMarker.rowNumber;
TW.log.info('Should display info for Row #' + selectedRowNo);
//thisWidget.setSelectedMarker(selectedRowNo);
thisWidget.cleanupTooltipMashup();
infoWindow.setContent('<div id="' + infoId + '" style="width:' + tooltipMashupWidth + 'px;height:' + tooltipMashupHeight + 'px;">Loading Tooltip Mashup...</div>');
//infoWindow.setContent('<div id="' + infoId + '" style="">Hello there, selected Row #' + selectedRowNo + ', "' + lastData[selectedRowNo]['name'] + '"</div>');
//infoWindow.setContent('Hello there, selected Row #' + selectedRowNo + '');
infoWindow.setPosition(markerInfo.latlng);
infoWindow.open(this.map, markerInfo.marker);
setTimeout(function () {
var mashupSpec = {};
mashupSpec.mashupName = thisWidget.getProperty('TooltipMashupName');
mashupSpec.mashupParameters = {};
var mashupParameters = thisWidget.properties['MashupParameters'];
if (mashupParameters === undefined)
mashupParameters = [];
var nParams = mashupParameters.length;
for (var paramNo = 0; paramNo < nParams; paramNo++) {
var paramInfo = mashupParameters[paramNo],
propName = paramInfo.ParameterName,
fldName = thisWidget.getProperty(propName),
propValue;
if (fldName === 'ALL_FIELDS') {
propValue = JSON.parse(JSON.stringify(dataInfotable));
propValue.rows.push(lastData[selectedRowNo]);
} else {
propValue = lastData[selectedRowNo][thisWidget.getProperty(propName)];
if (propValue !== undefined) {
mashupSpec.mashupParameters[propName] = propValue;
$('#' + infoId).mashup(mashupSpec);
}, 100);
return;
this.regionMouseOverEventListener = function (e) {
if(this.rowNumber != lastRegionNumber) {
regionInfoWindow.setContent(this.title);
regionInfoWindow.open(this.map);
regionInfoWindow.setPosition(this._tooltipCenter);
lastRegionNumber = this.rowNumber;
this.clickEventListener = function (e) {
return;
this.regionClickEventListener = function (e) {
thisWidget.setSelectedRegion(this.rowNumber);
this.dblclickEventListener = function (e) {
thisWidget.jqElement.triggerHandler('DoubleClicked');
this.cleanupRouteOverlays = function () {
try {
if (this.routePolyline !== undefined && this.routePolyline !== null) {
google.maps.event.clearInstanceListeners(this.routePolyline);
this.routePolyline.setMap(null);
delete this.routePolyline;
catch (destroyErr) {
// alert('error in destroy routePolyline');
this.cleanupPlannedRouteOverlays = function () {
try {
if (this.plannedRoutePolyline !== undefined && this.plannedRoutePolyline !== null) {
google.maps.event.clearInstanceListeners(this.plannedRoutePolyline);
this.plannedRoutePolyline.setMap(null);
delete this.plannedRoutePolyline;
// alert('error in destroy plannedRoutePolyline');
this.cleanupRegionOverlays = function () {
try {
if (this.currentRegions !== undefined && this.currentRegions !== null) {
for (var x = 0; x < this.currentRegions.length; x++) {
google.maps.event.clearListeners(this.currentRegions
google.maps.event.clearInstanceListeners(this.currentRegions
this.currentRegions
this.currentRegions
this.currentRegions = {};
catch (err) {
TW.log.error('error cleanupRegionOverlays', err);
this.cleanupMapOverlays = function () {
try {
if (this.polyline !== undefined && this.polyline !== null) {
google.maps.event.clearInstanceListeners(this.polyline);
this.polyline.setMap(null);
delete this.polyline;
// alert('error in destroy polyline');
try {
if (this.currentMarkers !== undefined) {
for (var x = 0; x < this.currentMarkers.length; x++) {
if (isMashupTooltipConfigured) {
google.maps.event.clearListeners(this.currentMarkers
google.maps.event.clearInstanceListeners(this.currentMarkers
delete this.markerLookup
this.markerLookup
this.currentMarkers
this.currentMarkers
this.currentMarkers
this.currentMarkers
this.currentMarkers
delete this.currentMarkers
this.currentMarkers = [];
this.markerLookup = [];
// alert('error in destroy markers');
try {
if (this.startMarker !== null && this.startMarker !== undefined) {
google.maps.event.clearListeners(this.startMarker, 'mouseover');
google.maps.event.clearListeners(this.startMarker, 'click');
google.maps.event.clearListeners(this.startMarker, 'dblclick');
google.maps.event.clearInstanceListeners(this.startMarker);
this.startMarker.setMap(null);
delete this.startMarker;
if (this.endMarker !== null && this.endMarker !== undefined) {
google.maps.event.clearListeners(this.endMarker, 'mouseover');
google.maps.event.clearListeners(this.endMarker, 'click');
google.maps.event.clearListeners(this.endMarker, 'dblclick');
google.maps.event.clearInstanceListeners(this.endMarker);
this.endMarker.setMap(null);
delete this.endMarker;
// alert('error in destroy start/end');
this.selectedRows = [];
this.cleanupMapContent = function () {
this.cleanupMapOverlays();
this.cleanupRouteOverlays();
this.cleanupPlannedRouteOverlays();
this.cleanupRegionOverlays();
try {
if(this.trafficLayer !== null && this.trafficLayer !== undefined) {
google.maps.event.clearInstanceListeners(this.trafficLayer);
this.trafficLayer.setMap(null);
this.trafficLayer = null;
delete this.trafficLayer;
try {
if (this.selectionMarker !== null && this.selectionMarker !== undefined) {
google.maps.event.clearInstanceListeners(this.selectionMarker);
this.selectionMarker.setMap(null);
delete this.selectionMarker;
this.cleanupTooltipMashup = function () {
try {
var mashupTooltips = $('#' + infoId);
if (mashupTooltips.length > 0) {
mashupTooltips.mashup('destroy');
TW.purgeJqElement(mashupTooltips);
this.serviceInvoked = function (serviceName) {
var widgetReference = this;
if (serviceName === 'AutoZoom') {
var effectiveBounds = new google.maps.LatLngBounds();
if(widgetReference.routeDataBounds !== undefined) {
effectiveBounds.union(widgetReference.routeDataBounds);
if(widgetReference.plannedRouteDataBounds !== undefined) {
effectiveBounds.union(widgetReference.plannedRouteDataBounds);
if(widgetReference.regionDataBounds !== undefined) {
effectiveBounds.union(widgetReference.regionDataBounds);
if(widgetReference.dataBounds !== undefined) {
effectiveBounds.union(widgetReference.dataBounds);
widgetReference.map.fitBounds(effectiveBounds);
}, 100);
} else {
TW.log.error('Google map widget, unexpected serviceName invoked "' + serviceName + '"');
this.beforeDestroy = function () {
this.cleanupMapContent();
try {
google.maps.event.clearInstanceListeners(this.map);
catch(destroyErr) {
this.cleanupTooltipMashup();
//// put the map back in the body to be reused
//$('body').append($('#global-map'));
//$('#global-map').hide();
dataInfotable = null;
thisWidget = null;
this.map = null;
delete this.map;
this.updateProperty = function (updatePropertyInfo) {
var zoomOnDataRefresh = true;
if( userHasPannedOrZoomedSinceAutoZoom === true ) {
zoomOnDataRefresh = false;
break;
break;
zoomOnDataRefresh = initialData;
initialData = false;
break;
default:
if (updatePropertyInfo.TargetProperty === 'Zoom') {
var zoom = parseInt(updatePropertyInfo.RawSinglePropertyValue);
this.map.setZoom(zoom);
return;
if (updatePropertyInfo.TargetProperty === 'ShowTraffic') {
this.setProperty('ShowTraffic', updatePropertyInfo.RawSinglePropertyValue);
if(this.trafficLayer === undefined || this.trafficLayer === null) {
else{
if(this.trafficLayer !== undefined) {
if (updatePropertyInfo.TargetProperty === 'SelectedLocation') {
var location = updatePropertyInfo.RawSinglePropertyValue;
if (location != undefined && location.latitude != 0 && location.longitude != 0 && location.latitude != undefined && location.longitude != undefined) {
this.moveSelectionMarker(location);
this.map.setCenter(this.map.getCenter());
} else {
thisWidget.setProperty('SelectedLocation', undefined);
return;
var redrawRoute = function() {
var showRoute = this.getProperty('ShowRoute');
if(showRoute) {
this.routeDataBounds = new google.maps.LatLngBounds();
var dataRows = updatePropertyInfo.ActualDataRows;
var locationField = this.getProperty('RouteLocationField');
var LatLngList = [];
var nRows = dataRows.length;
for (var rowNumber = 0; rowNumber < nRows; rowNumber++) {
var row = dataRows[rowNumber];
var thisLocation = row[locationField];
if (thisLocation !== undefined && thisLocation.latitude !== 0.0 && thisLocation.longitude !== 0.0) {
var latlng = new google.maps.LatLng(thisLocation.latitude, thisLocation.longitude);
LatLngList.push(latlng);
this.routeDataBounds.extend(latlng);
if (LatLngList.length > 1) {
this.routePolyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.routeStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.routeStyle.lineThickness)
this.routePolyline.setMap(thisWidget.map);
if(zoomOnDataRefresh ) {
// Autofit if we have more than one data point
if(this.routeDataBounds !== undefined) {
effectiveBounds.union(this.routeDataBounds);
if(this.regionDataBounds !== undefined) {
effectiveBounds.union(this.regionDataBounds);
if(this.dataBounds !== undefined) {
effectiveBounds.union(this.dataBounds);
this.map.fitBounds(effectiveBounds);
else {
if (LatLngList.length > 0) {
this.map.setCenter(LatLngList[0]);
this.map.setZoom(this.map.getZoom());
return;
if (updatePropertyInfo.TargetProperty === 'RouteData') {
redrawRoute.call(this);
var redrawPlannedRoute = function() {
var showRoute = this.getProperty('ShowPlannedRoute');
if(showRoute) {
this.plannedRouteDataBounds = new google.maps.LatLngBounds();
var locationField = this.getProperty('PlannedRouteLocationField');
this.plannedRouteDataBounds.extend(latlng);
this.plannedRoutePolyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.plannedRouteStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.plannedRouteStyle.lineThickness)
this.plannedRoutePolyline.setMap(thisWidget.map);
if(this.plannedRouteDataBounds !== undefined) {
effectiveBounds.union(this.plannedRouteDataBounds);
else {
return;
if (updatePropertyInfo.TargetProperty === 'PlannedRouteData') {
redrawPlannedRoute.call(this);
var redrawRegions = function() {
var tooltipField1 = this.getProperty('RegionTooltipField1');
var tooltipLabel1 = this.getProperty('RegionTooltipLabel1');
var tooltipField2 = this.getProperty('RegionTooltipField2');
var tooltipLabel2 = this.getProperty('RegionTooltipLabel2');
var tooltipField3 = this.getProperty('RegionTooltipField3');
var tooltipLabel3 = this.getProperty('RegionTooltipLabel3');
var tooltipField4 = this.getProperty('RegionTooltipField4');
var tooltipLabel4 = this.getProperty('RegionTooltipLabel4');
var showRegions = this.getProperty('ShowRegions');
var showRegionTooltips = this.getProperty('ShowRegionTooltips');
if(showRegions) {
this.regionDataBounds = new google.maps.LatLngBounds();
var enableRegionSelection = this.getProperty('EnableRegionSelection');
var locationsField = this.getProperty('RegionLocationsField');
var locationField = this.getProperty('RegionLocationField');
var fillOpacity = this.getProperty('RegionFillOpacity');
this.currentRegions = [];
var locationTable = row[locationsField];
if(locationTable !== undefined) {
var RegionLatLngList = [];
var regionDataRows = locationTable.rows;
var nRegionRows = regionDataRows.length;
var polygonBounds = new google.maps.LatLngBounds();
for (var regionRowNumber = 0; regionRowNumber < nRegionRows; regionRowNumber++) {
var regionRow = regionDataRows[regionRowNumber];
var thisLocation = regionRow[locationField];
RegionLatLngList.push(latlng);
this.regionDataBounds.extend(latlng);
polygonBounds.extend(latlng);
if (RegionLatLngList.length > 1) {
var hasRegionFormatting = thisWidget.properties['RegionFormatting'] !== undefined;
var formatStyle = thisWidget.regionStyle;
if (hasRegionFormatting) {
formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['RegionFormatting'] });
var regionProps = {
paths: RegionLatLngList,
strokeColor: formatStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(formatStyle.lineThickness),
fillColor: formatStyle.backgroundColor,
fillOpacity: fillOpacity
var regionPolygon = new google.maps.Polygon(regionProps);
var regionLayerField = thisWidget.properties['RegionLayerField'];
if( regionPolygon['setZIndex'] !== undefined ) {
if(regionLayerField !== undefined && regionLayerField !== '') {
var regionLayer = row[regionLayerField];
if(regionLayer !== undefined)
regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + regionLayer);
else
regionPolygon.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
else {
regionPolygon._assignedFillColor = formatStyle.backgroundColor;
regionPolygon._assignedStrokeColor = formatStyle.lineColor;
regionPolygon._assignedStrokeWeight = parseInt(formatStyle.lineThickness);
regionPolygon.rowNumber = rowNumber;
regionPolygon.rowData = row;
regionPolygon._isSelected = false;
regionPolygon._tooltipCenter = polygonBounds.getCenter();
regionPolygon.setMap(thisWidget.map);
if(enableRegionSelection) {
google.maps.event.addListener(regionPolygon, 'click', this.regionClickEventListener);
this.currentRegions.push(regionPolygon);
if(showRegionTooltips) {
var title = '';
if (tooltipField1 !== undefined && tooltipField1 !== '') {
if (tooltipLabel1 !== undefined && tooltipLabel1 !== '')
title = title + tooltipLabel1 + ' : ';
else
title = title + tooltipField1 + ' : ';
title = title + row[tooltipField1];
if (tooltipField2 !== undefined && tooltipField2 !== '') {
if (title.length > 0)
title = title + '<BR>';
if (tooltipLabel2 !== undefined && tooltipLabel2 !== '')
title = title + tooltipLabel2 + ' : ';
else
title = title + tooltipField2 + ' : ';
title = title + row[tooltipField2];
if (tooltipField3 !== undefined && tooltipField3 !== '') {
if (tooltipLabel3 !== undefined && tooltipLabel3 !== '')
title = title + tooltipLabel3 + ' : ';
else
title = title + tooltipField3 + ' : ';
title = title + row[tooltipField3];
if (tooltipField4 !== undefined && tooltipField4 !== '') {
if (tooltipLabel4 !== undefined && tooltipLabel4 !== '')
title = title + tooltipLabel4 + ' : ';
else
title = title + tooltipField4 + ' : ';
title = title + row[tooltipField4];
if (title.length > 0) {
regionPolygon.title = title;
google.maps.event.addListener(regionPolygon, 'mouseover', this.regionMouseOverEventListener);
if(zoomOnDataRefresh) {
else {
return;
if (updatePropertyInfo.TargetProperty === 'RegionData') {
redrawRegions.call(this);
var redrawMap = function() {
dataInfotable = {
dataShape: {
fieldDefinitions: updatePropertyInfo.DataShape
rows: []
this.dataBounds = new google.maps.LatLngBounds();
lastData = dataRows;
var locationField = this.getProperty('LocationField');
var tooltipField1 = this.getProperty('TooltipField1');
var tooltipLabel1 = this.getProperty('TooltipLabel1');
var tooltipField2 = this.getProperty('TooltipField2');
var tooltipLabel2 = this.getProperty('TooltipLabel2');
var tooltipField3 = this.getProperty('TooltipField3');
var tooltipLabel3 = this.getProperty('TooltipLabel3');
var tooltipField4 = this.getProperty('TooltipField4');
var tooltipLabel4 = this.getProperty('TooltipLabel4');
var showMarkers = this.getProperty('ShowMarkers');
var showMarkerTooltips = this.getProperty('ShowMarkerTooltips');
if(showMarkerTooltips == null || showMarkerTooltips == undefined)
showMarkerTooltips = true;
var enableMarkerSelection = this.getProperty('EnableMarkerSelection');
if (showMarkers) {
var markerProps = {
map: this.map,
position: latlng
if(showMarkerTooltips) {
var title = '';
else
title = title + '\n';
else
else
else
if (title.length > 0 && !isMashupTooltipConfigured) {
markerProps.title = title;
var markerField = thisWidget.properties['MarkerField'];
var hasFormatting = thisWidget.properties['MarkerFormatting'] !== undefined;
if (hasFormatting) {
var formatStyle = TW.getStyleFromStateFormatting({ DataRow: row, StateFormatting: thisWidget.properties['MarkerFormatting'] });
if (formatStyle.styleDefinitionName !== undefined) {
markerProps.icon = formatStyle.image;
} else {
markerProps.icon = thisWidget.markerStyle.image;
else
if(markerField !== undefined && markerField !== '') {
var markerImagePath = row[markerField];
if(markerImagePath !== undefined && markerImagePath !== '') {
markerProps.icon = markerImagePath;
var marker = new google.maps.Marker(markerProps);
marker.rowNumber = rowNumber;
marker.rowData = row;
marker._isSelected = false;
marker._assignedIcon = markerProps.icon;
var markerLayerField = thisWidget.properties['MarkerLayerField'];
if(markerLayerField !== undefined && markerLayerField !== '') {
var markerLayer = row[markerLayerField];
if(markerLayer !== undefined)
marker.setZIndex(google.maps.Marker.MAX_ZINDEX + markerLayer);
else
marker.setZIndex(google.maps.Marker.MAX_ZINDEX + 1);
else
this.currentMarkers.push(marker);
this.markerLookup.push({ latlng : latlng, marker : marker});
// This funky code is because we are in a loop and need to do some closure magic
google.maps.event.addListener(marker, 'mouseover', this.mouseOverEventListener);
if (enableMarkerSelection) {
google.maps.event.addListener(marker, 'click', this.clickEventListener);
google.maps.event.addListener(marker, 'dblclick', this.dblclickEventListener);
this.dataBounds.extend(latlng);
var showPathBetweenMarkers = this.getProperty('ShowPathBetweenMarkers');
if (LatLngList.length > 1 && showPathBetweenMarkers) {
this.polyline = new google.maps.Polyline({
path: LatLngList,
strokeColor: thisWidget.pathStyle.lineColor,
strokeOpacity: 1.0,
strokeWeight: parseInt(thisWidget.pathStyle.lineThickness)
this.polyline.setMap(thisWidget.map);
if (this.getProperty('ShowEndMarker')) {
this.endMarker = new google.maps.Marker({
map: this.map,
position: LatLngList[LatLngList.length - 1],
title: "End",
icon: this.endMarkerStyle.image
this.endMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
if (this.getProperty('ShowStartMarker')) {
this.startMarker = new google.maps.Marker({
map: this.map,
position: LatLngList[0],
title: "Start",
icon: this.startMarkerStyle.image
this.startMarker.setZIndex(google.maps.Marker.MAX_ZINDEX + 2);
else {
// Finally, handle any pre-selected markers
var selectedRowIndices = updatePropertyInfo.SelectedRowIndices;
if (selectedRowIndices !== undefined) {
for (var selectedRowIndex = 0; selectedRowIndex < nSelectedRows; selectedRowIndex++) {
if (updatePropertyInfo.TargetProperty === 'Data') {
redrawMap.call(this);
switch (updatePropertyInfo.TargetProperty) {
case 'ShowPathBetweenMarkers':
case 'ShowStartMarker':
case 'ShowEndMarker':
case 'ShowMarkers':
thisWidget.setProperty(updatePropertyInfo.TargetProperty, updatePropertyInfo.RawSinglePropertyValue);
break;
case 'ShowRoute':
break;
case 'ShowPlannedRoute':
break;
case 'ShowRegions':
break;
I'm sorry, zoneColor it was for my case. You must replace it for the color that you want (format #000000).
