Hi All,
I want to configure blog widget with set of tags which can help me in filtering the Conversation in blog widget. But not aware of how to use tags as input to blog widget.
Pravin
It has been a very very long time since I've used this but ...
The tag picker should allow an assignment of a tag vocabulary - this is basically Data Tags
So if you haven't yet, create a Data Tag Vocabulary and enter in your terms, or set it to dynamic to allow creation of new terms within the vocabulary dynamically.
I hope that after that it is all self-explanatory.
People enter blog entries, add their tags. You filter you see those entries.
Thanks for your reply,
I tried the same and thought that will work but not able to see those vocabulary in the drop down. So curious to know what needs to be done to view that. Can you please help on that?
Pravin
Do you already have terms in the vocabulary?
Correct as below
Not too sure, perhaps try entering some blog entries with tags?
Again it's been super long since I've used this.
