How to write into class aspects field?
Michail
9-Granite
Hello, I need to find a non-destructive way of writing into a class aspects constant ASPECT_DATACHANGETHRESHOLD​ at ThingShape level. I'd be grateful for your help!
8 REPLIES 8
tmousaw
(To:Michail)
You can set the aspect ​dataChangeThreshold​ directly in ThingWorx Composer when defining the property on the ThingShape under "Data Change Info > Change Threshold".  Are you looking for a means to set this aspect that does not involve the ThingWorx Composer?
Michail
9-Granite
(To:tmousaw)
correct
tmousaw
(To:Michail)
I'd like to have more context on your particular use case.  Can you elaborate?  Do you have an existing ThingShape and want to set the ​dataChangeThreshold​ aspect programmatically?  Or are you programmatically creating a ThingShape and need to set the aspect of the ​dataChangeThreshold​ of the properties you are adding?
Michail
9-Granite
(To:tmousaw)
Tim Mousaw​, please view the following post.
tmousaw
(To:Michail)
Thank you for the context.
After some investigation, I do not believe there is any way for you to accomplish what you are trying programmatically.  I do believe that what you are trying to do ​should​ be available programmatically.  Therefore, I would suggest you submit a support ticket for your use case.  I will also respond to the other thread.
Michail
9-Granite
(To:tmousaw)
Thank you Tim Mousaw​, I've submitted a ticket.
posipova
20-Turquoise
(To:Michail)
You can set aspects in your java extension, ThingWorx Eclipse plugin makes it especially easy.
Polina Osipova​, would an app user be able to set it?
