Hello;
I want to calculate sum of specific "timestamp" column rows data except first and last row Please suggest how do I write JavaScript code to calculate sum of "timestamp " column rows data except first and last row??
Thanks in advance
Hi @RM12 ,
One way to fulfill this business requirement you can refer:
1. Suppose you have create a service to get the needed query result of this database table to a infotable parameter named tableResult which include 2 columns(heartRange and timestamp);
2. Create a new infotable through a service which will derived one number field for caculating
var tableResult=me.tableResult;
var params = {
types : "NUMBER",
columns : "number",
t : tableResult,
expressions : "1"
// DeriveFields
var result = Resources['InfoTableFunctions'].DeriveFields(params);
3. Create a datashape contains 3 fields - heartRange, timestamp, number
4. Create a service to caculate:
var tr = me.tableResult();
var st=Date.parse(StartTime); //inputparameter
var et=Date.parse(EndTime); //inputparameter
var params = {
infoTableName : "queryHeartRange",
dataShapeName : "queryHeartRangeDatashape"
var queryHeartRange = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for (var i=0;i<tr.rows.length;i++){
var ct=Date.parse(tr.rows[i].timestamp);
if (st<=ct && ct<et){
queryHeartRange.AddRow(tr.rows[i]);
var params1 = {
columns : "number",
aggregates : "SUM",
t : queryHeartRange};
var totalNumber = Resources['InfoTableFunctions'].Aggregate(params1);
var result = totalNumber.SUM_number;
You can also add your query logic in above js code.
Best Regards,
/Yoyo
Hello @RM12 ,
Before getting to answer of this question, we should first know:
/Yoyo
Thanks for your reply, I have Database table and getting continuous data with two column name heart rate and timestamp .set Hr ranges between 0-90 ,90-110,110-130,130-150 and 150 above .Suppose in 1 hour how many time heart rate stay in between ranges. please suggest how do I calculate time between according to heart rate ranges???
Hi @RM12 ,
var params = {
types : "NUMBER",
columns : "number",
t : tableResult,
expressions : "1"
// DeriveFields
var params = {
var params1 = {
columns : "number",
aggregates : "SUM",
Best Regards,
/Yoyo
Hi @RM12.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
