Actually I mean to say that suppose I create a mashup the I want that whoever does the login through respective credentials to access that mashup, the username must be seen on the mashup like "Hi,Prashant".
So is it possible and if yes then should I create a service for that?
And what else should I do to achieve that.
1. Put 1 label in the mashup
2. There are 3 tab in the right hand side "data","session","user".
3. Open user tab and set name of the user with text of the label.
4. save mashup and view it will show your logged user in the mashup
