Hyperlink in Grid Advanced (Thingworx 8.5.2)
VS_9760165
Hi ,
I have a Grid Advance in Mashup , running on Thingworx 8.5.2 , i had to add Hyperlink as Column Value. and i added it using Column Base Type as 'Hyperlink' but at runtime in grid its not Clickable. please see below screen..
1 ACCEPTED SOLUTION
Ashritha
(To:VS_9760165)
Hi @VS_9760165 ,
It may be due to grid settings, Please follow below steps
  1. Click on grid
  2. Click on Configure and Bindings
  3. Select Link column
  4. Click on Column Renderer & State Formatting tab
  5. Select Renderer : HYPERLINK
  6. Select Other parameters as shown in the image below
5 REPLIES 5
Hi @Ciprian-Traian
above post is more about Checkbox but they have provided below Answer for Hyperlink . see below screenshot of that post..and already i did the same but not clickable.
Ashritha
(To:VS_9760165)
Create a field/column with Hyperlink as datatype and bind data to advanced grid. The Link will appear as below
When view is clicked , navigates to target link .
Hi @Ashritha ,
I have added field like below in infotable..
In datashape have added Link Field with Basetype Hyperlink as below...
getting output as..
But still not clickable...its highlighting complete row when i move cursor to row as in above 1st post . what do i need ?
Ashritha
(To:VS_9760165)
Hi @VS_9760165 ,
  1. Click on grid
