Server=localhost
Port=5432
Database=thingworx
Tablespace=thingworx
Tablespace Location=/ThingworxPostgresqlStorage
Admin User=postgres
Thingworx User=twadmin
Start Execution
./thingworx-database-setup.sql: No such file or directory
Press any key to continue . . .
Arunprasath, this should exist in the install folder, judging by the details above you are installing for the first time, right? This particular file together with bunch of other required SQL and bat files are located in the install folder which you can check in your downloaded package
its there sir
Could you please share how you are formulating the batch file execution, basically the command you are using to execute that batch file?
