I do not see any dataset in the Analytics Builder with the Tractor sample.
mpagliotta
1-Newbie
I installed Data Connect in my CentOS VM where is installed also THingWorx Analytics 8.0.
I'm imported entities downloaded from here: How to use DataConnect when sending property values from the ThingWorx platform to ThingWorx Analytics.
and i runned the jar simulator in my windows VM where is installed ThingWorx Platform 8.0:
In the Tractor Thing i see data:
So, i use the DAD to run data to Analytics:
but in the dataset area there are no dataset:
I attached the ThingWorx logs and PostgreSQL logs.
Marco
4 REPLIES 4
cmorfin
(To:mpagliotta)
Hi Marco
We seem to have a 404 error which would indicate ThingWorx does not find DataConnect.
Could you please check the URI under SYSTEM > Subsystems > PlatformSubsystem: for ThingWorx DataConnect URL Path if it points to the right location.
It would be good to take this URL and add /about/versioninfo to the end of it and check in a browser what is the result of this URI (please post the output here too).
Also could you post the following files:
- Tomcat log files (<tomcat>/logs)
- DataConnect log files (/opt/dataconnect/logs)
- DataConnect config file (/opt/dataconnect/config)
Thank you
Kind regards
Christophe
Hi
The i can see the ThignWorx Analytics from VM THingworx Platform:
This is URL path in subsystem:
I attached the tomcat logs and data connect configuration file (no data connect logs found).
Kind regards.
Marco P.
cmorfin
(To:mpagliotta)
For the record, this has been solved offline.
Several issues occurred:
- dataconnect.conf was still having the default value and needed to be updated to the site info
- ThingWorx DataConnect URL Path needs to point tot he DataConnect server and not the ThingWorx Analytics one
- firewall was blocking some accesses
- ThingWorx DataConnect Application Key should not be left blank
dataset was then created successfully from ThingWorx to ThingWorx Analytics Server via DataConnect
Hi Marco Pagliotta,
I am also starting my analytics with this tractor example.
for where we will get Similator jar file ?
Raji
