The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello All
1)Can we import entites from a lower Thingworx version to upper version I tried but faced issue.
2)How to upgrade Thingworx from 9.3.15 to 9.5.0 without deleting the data
Hi @Pratik_Aswale Use the below help center link.
let us know at which step, you are facing the issue.
Please check this link for Upgrade from 9.3 to 9.5 - Upgrading ThingWorx (ptc.com)
Regarding 1st Point, you can import it but you need migrate your mashup to 9.5 to replace legacy widget and expressions.
Please check Application log for error message while importing entities.
/VR
Hey VR,
I tried but the information is not clear. I had installed Thingworx 9.3.15 using thingworx foundtion installer. If possible coud you please share the steps
Using installer
