How can I do it using ThingView widget?
If not ThingView is there any other widget in Thingworx or we can find in market place?
The ThingView widget is a licensed component that comes with:
Hi @SD_10134497,
It appears that a response to this post answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
